Hello, does anyone know if Tamiya ever released a spare rotor for the RX540Vz motor as they did for the technipower (rotor 5227) and technituned (rotor 5231) motors? If so, do you know the part number.
Jeff |
I have got a sd for sale but the vz ... dont know!
good question. isn't that the same rotor? www.ebay.nl/itm/334348010521
The TB database lists the Technituned as a 27 single & the Technigold as a 21 single, so no, not the same rotor.
I looked in my Tamiya catalogues, 1986 shows the Technituned, Techituned rotor, Technipower motor, Technipower brush set, and the Technipower rotor - but no Technigold motor or anything for it. 1987 and 1988 show the Technigold motor only. 1989 shows the Technigold motor, and a brush set for it - part 50312 1990 moves away from the picture grid format, but the Technigold motor & brushes are listed. 1991, 92, 93, ditto 1994, nothing "Techni" is mentioned at all. I don't have anything like a full perm of the RC Guide Books, but I do have one from 1987 (with the Bigwig on the front) - that only has the Technigold motor. I can't say definitively that Tamiya never released a Technigold rotor, but I would expect it to have been documented, so it's probably a no
The following user(s) Liked this: stingray-63, poebe
I never saw a vz technigold rotor in spare. But I know that graupner sold it. Maybe a source. And from mabuchi 0 spares available. Like if they never built this motor.
Maybe find another rotor similar from yokomo
the rx540sd is number 5231
there is also this one 5227 do we miss 5228 5229 5230? This rotor can be used in the technipower and technituned motor. wat are the differences between those 2? interesting treath! 50225 RX540SD TECHNIPOWER Type:Brushed Timing Adjustable Maintenance Rebuildable Turns: 23x1Wire: Normal voltage: 6 - 8,4 V Torque: 315 g/cm at best efficiency and 7,2V RPM: 20300 rpm at best efficiency and 7,2V Current: 11,2 Amp 50230 RX540SD TECHNITUNED Type: Brushed Timing Adjustable Maintenance Rebuildable Turns: 27x1Wire: Normal voltage: 6 - 8,4 V Torque: 290 g/cm at best efficiency and 7,2V RPM: 17200 rpm at best efficiency and 7,2V Current: 11,2 AmpKV
Last edit: by poebe.
Same on the rz. They have same cage / stator.
