According to this topic :
TC forum discussion This should be a fit - when you take care of the grub screw : Towerhobbies pinion |
Hi Kevin,
You are in for a challenge... First, the pinion is pressed on, so you will have to use heat to get it off. Secondly, the pinion is nearly unique. It has 10 teeth, and the tooth module is apparently 0,7. (I'm not sure) I have also gathered that the Spur gear is module 0,6 so a pinion of 0.6 module might fit as well. I think the difficult part is to get one that only has 10T. This is as far as I can get... anyone with more info? -Lars EDIT: posted at same time as Edou above. But I actually think we agree Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
