Re: grasshopper, electrical woes 15 years 1 month ago #2829
Going forward should be proportional and very controllable.
Abruptness is more the sort of thing for a worn MSC. ;)
I'll see if I can figure out an answer with more content...
Re: grasshopper, electrical woes 15 years 1 month ago #2830
maybe it has something to do with the capacitor on the motor?
the manual says 2 x 0.1uf from each pole to the motor case. mine has one which is connected between + and - and is marked 120 underlined and its a kind of red/pink colour
Re: grasshopper, electrical woes 15 years 1 month ago #2831
Trying out another motor on the ESC could certainly tell a lot about the cause...
Re: grasshopper, electrical woes 15 years 1 month ago #2832
i would have to buy a new motor, the only ones i got are on my moat and they are the same motors
Re: grasshopper, electrical woes 15 years 1 month ago #2839
I've reasearched a bit but I can't give a sensible solution for that myself without having the car in front of me...
Not being able to suddenly go from forward to reverse is normal with this ESC.
You'd otherwise need a controller that only has forward/reverse or one with a function on it to turn off the break.
It does indeed save the gears but it's a different kind of driving experience... :)
Re: grasshopper, electrical woes 15 years 1 month ago #2840
its new to me so i am sure i will get used to it, it came so quick it surprised me so i still have to paint it and get a new front bumper before i can take it for a spin.
the capacitors on the motor still concerns me. if they are wrong will i blow the ESC or the motor? still considering fitting a fuse even though i have been advised it is not necessary.my budget is close to empty right now but i will persevere and keep updating on the build forum
Re: grasshopper, electrical woes 15 years 1 month ago #2843
Better to be surprised at the speed of delivery than having to really wait on your parts. ;)
Experiencing the latter myself at the moment...
Maybe I can find some new info for you on the capacitator subject.
I wouldn't be very worried about it having a disastrous effect myself, nor would I about the fuse box.
The fact that the car isn't running smoothly would occupy me most... :huh:
Hope to see new result soon! :cheer:
Re: grasshopper, electrical woes 15 years 1 month ago #2852
I suspect it's down to ESC setup - yes it's automatic on that one, but you do still have to operate it "correctly". Edou I think already mentioned this, but you do need to make sure the transmitter has the throttle trim & stick in the zero (central) position, turn it on, then the car - this will set the neutral point on the ESC, the first time you use the throttle, go all the way to maximum up on the stick, this will set the maximum forward point on the ESC.
If you've had the trim position out (especically upwards), and/or have only just blipped the throttle, the neutral & max forward points will be wrong, which could lead to the throttle behaviour you mentioned.
Try doing the setup again (or "properly" ;) ) before you start worrying something is wrong ... but TBH, diagnosis of problems can only really be done by substitution to isolate the offending item :(
Re: grasshopper, electrical woes 15 years 1 month ago #2853
i did have the trims set to middle positions and turned on the transmitter before the car, but i think i probably just blipped the throttle initially as i just wanted to see if it worked! i will do it again today make sure i go to full throttle straight away.
thanks
Re: grasshopper, electrical woes 15 years 1 month ago #2871
For an extra bit of information - the capacitors are there to prevent electrical interference built up by the system itself.
The Jamara has two of them installed inside the motor housing. :)
Time to create page: 0.120 seconds
