No fighting here. Mostly agreeing actually.
But I am concerned that the old Acoms receiver might have the polarity reversed. Anybody that has a receiver like this and has hooked it up to newer electronics? It would be an Acoms ARC-227... That wasn't a Futaba but a (very) old Acoms! |
I was pretty sure the "C" model Acoms RX has normal sockets & wire layout - even if they are on leads rather than in the body of the RX - I went hunting & found some info at studio68.no/rc/...sp?id=6200 which seems to confirm that - I guess the "C" model RX is a halfway house between old skool Acoms RXs (proprietory plugs & pinout/wire order) & "modern" RXs (pins on board the RX in a standardised layout, with BEC).
wow, ordered the ESC yesterday off ebay, turned up in the post today!!!
fitted and working, yippee:woohoo: still not quite sure about the motor capacitor thing, and do i really need to fit an inline fuse? |
Last edit: by agemax.
The following user(s) Liked this: agemax
i made sure i did all that on initial start. i think maybe it has something to do with reverse being brake? maybe?.
if i go forward then slam it in reverse it stops then starts going backwards, whereas before if i did the same it would go in reverse straight away, wheel spinning as it went. probably good to stop ruining the gears i suppose |
