Front shocks for Bigwig 14 years 11 months ago #4001
Hay
so I am on this Bigiwg project and having trouble finding a kit for the front shocks. I got the kit for the rear shocks, tmaiya p/n 50304 but am having trouble getting the complete kit for the fronts, p/n 50305
can anyone help? I ahve also seen some guy used Traxxas shocks all round instead of the Tamiya shocks, is any one able to tell me teh Traxas p/n for the ones I should use.
the above probably sounds a bit basic and amateur, I am, this is all new to me, I thought I would be able to buy it all from E-bay
thanks for your help
Hay Ewe
Front shocks for Bigwig 14 years 11 months ago #4002
The modern version of the CVA short shock unit has parts number 50520.
Shortest setting is 3mm longer though... and they are black.
If you have the correct length, many kinds of shocks could be fitted one way or another.
But no blasphemous Traxxas on a vintage Tamiya please! ;) :lol:
Re: Front shocks for Bigwig 14 years 11 months ago #4003
There is an original yellow set on eBay at the moment also :
Re: Front shocks for Bigwig 14 years 11 months ago #4007
thanks Edou
I shall investigate the new p/n you quote.
as for the original kit, I had found them on e-bay and bid on them but knowing that there were alternates, they went past my limit, in the end went for 35 UK pounds.
Hay Ewe
Re: Front shocks for Bigwig 14 years 11 months ago #4008
If you don't feel the need to put all vintage parts on your car, 35 pounds will buy you some very nice shocks.
For the front and the rear - with even some change for other parts...
Brands like GPM and Yeah Racing also make great aftermarket stuff.
Re: Front shocks for Bigwig 14 years 11 months ago #4017
Btw - I put some links to stores "underneath" the brand names.
If you do a search on the approximate length needed, you're sure to get a few results.
For example 80mm is quite a common size... :)
Time to create page: 0.160 seconds
