Avante antenna tube colour 14 years 11 months ago #4766
Does anyone know the colour of the antenna tube on the original Avante?
Black, white or clear?
Tom
Last edit: by TommieG.
Re: Avante antenna tube colour 14 years 11 months ago #4767
It was blued steel in an alloy holder ... pretty sure it was of the same type found on the Hotshot, Boomerang & Bigpig - I say "pretty" sure as I just looked & though it looks the same, it seems to have a different part number :S
Re: Avante antenna tube colour 14 years 11 months ago #4768
The antenna is the steel one, with the aluminum base. part no. 5365002.
It's the same on a lot of models, The Hotshot, Boomerang, Bigwig, Avante, Hotshot II, Super Sabre, etc, etc.
-Lars
Re: Avante antenna tube colour 14 years 11 months ago #4769
Dang! You're right..... I always believed it had a plastic tube, maybe because I had one on mine.... Never even considered it had the metal rod type from the Hotshot.
Thanks.
Tom
Re: Avante antenna tube colour 14 years 10 months ago #4793
Completely unrelated, but if you're fed up with paying extortionate prices for plastic antenna pipes, (& aren't particularly concerned with colour) look at buying nylon tube by the reel - I usually land 50m of 1/8" O/D natural (Nearly clear) nylon instrument air tubing for around 10 GBP (Same stuff as I've used for the hydraulics on my TXT). There seem to be quite a few people on Ebay selling it, but I usually get mine from RS or engineering suppliers through work. I've also heard that it's possible to dye nylon any colour you like with fabric dyes, but I've not tried that yet
Re: Avante antenna tube colour 14 years 10 months ago #4800
Thanks - I've thought before there must be a better way than paying
Re: Avante antenna tube colour 14 years 10 months ago #4804
The only thing that I've found can be a slight nuisance is when you buy tubing 'on the reel' it tends to be curly, but it's easily straightened by holding it taught between 2 points (eg 1 end in a vice, hold the other end with pliers) & pouring boiling water over it, or giving it a tickle with a hot air gun (Keep holding it taught whilst it cools). Don't pull too hard whilst doing this or it'll stretch....
Time to create page: 0.126 seconds
