Bigwig spares 14 years 9 months ago #6025
ello can anyone help me in sourcing spares for my bigwig? i need part no 90005208 or "B" parts 3, its the what i can only descibe as the hub the plastic triangle shape bit the wheel fits on..... sorry if not very clear!!!! im also after some switch grease for the speed controller... if anyone can help will be very grateful
Re: Bigwig spares 14 years 9 months ago #6028
There's two auctions on eBay at the moment for B trees...
But I don't think it absolutely necessary to go back to the original setup.
With some modern 12mm hexagonal hubs you could fit all kinds of wheels if the offset is right. :cheer:
If the wheels that came with the car are still in good nick, it might be worth looking at a B tree.
But if you're planning on running the car a lot, I'd make the change to the 12mm hexes and some matching wheels...
Re: Bigwig spares 14 years 9 months ago #6031
Welcome on board nojmo1000 :)
Unfortunately I don't think anyone is going to have those parts just lying around spare in a toolbox - there were only 4 supplied with the cars they fit on, unlike the 12mm nex hubs no-one makes a hopup part - and they always break!
The hubs on the Bigwig I bought & (sort of) restored last year looked fine ... until I tried to remove them when they all just crumbled :(
On the plus side, there should (other than money) be no problem about replacing broken hubs with functional ones - although getting blue ones will be nigh on impossible ... the "B" parts from the re-released Boomerang fit but are black (&
Re: Bigwig spares 14 years 9 months ago #6032
I don't know what the offset on the "Mooncraft" wheels is - but I know they have +1mm offset on the front & +1.5mm on the rear _compared to Hotshot wheels_, according to my measurements...
So, does anyone know if Hotshot wheels have any offset?
TBH I think the offset trivial enough not to worry about it :)
BTW, Hotshot wheels look ok on a Bigwig, modern wheels (unless they are white & dished) just look _wrong_ to me :S
Re: Bigwig spares 14 years 9 months ago #6076
What wheel adaptors are on Thundershot etc? (I should know this but mine's in the loft at the mo) - there's still loads of bits for them knocking about. Failing that, buy a whole car - they're cheap at the mo cos nobody wants them (In my experience....)
Re: Bigwig spares 14 years 9 months ago #6080
These wheel adapters are used on a lot of models, like hotshot, hotshot 2, supershot, boomerang, super sabre etc. They are easy to obtain, but just have different colours which you can paint if you wanna go vintage setup.
Cheers and gl
Restoring Countach 58005
Restoring 58015 RR
Restoring 58098 F40
Restoring Audi Quattro rally
Restoring Mk.1 Sand Scorcher
Restoring Porsche 936
Re: Bigwig spares 14 years 9 months ago #6081
same goes for thundershot, eddrick
Restoring 58015 RR
Restoring 58098 F40
The following user(s) Liked this: eddrick
Time to create page: 0.291 seconds
