I am putting a Thorp Mfg. Ball Differential in my Fox. I realize this is kind of a stupid question but is there anyone who can give a little advice on how tight to set the adjustment screw? The instructions a pretty darn vague. I know I most likely will have to adjust it but the way the instructions are worded, I may have to do it 2-3 times. At least with someone's experienced advice, I could get it closer to good the first time and not have to keep taking it apart.
Last edit: by jpar63.
I have no experience with Thorp diffs, but my guess is that you have incompatible parts.
According to THIS PAGE , there are som different variants for the Fox diffs, both with and without original axles/dogbones. Here is an extract:
EDIT: I replied to the post before you edited, but anyway.. PS: no questions are stupid Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
My experience of ball diffs in buggies goes something like "Tighten it up as much as you dare without breaking something & hope it stops slipping. Then, when it keeps slipping regardless of how tight it is, tighten it some more, at which point it'll break. Then, throw it in the bin & put a gear diff in & never have problems again".
Oh no, just remembered, I've got an Astute to do at some point....
