If you put a screw through it, you can limit (and adjust) the maximum roll of the chassis.
Edit - and influence understeer/oversteer... I put some titanium screws in my C11 so it'll give some nicely coloured sparks when hitting the tarmac. |
I think it's about the maximum angle the T-bar can make compared to the chassis...
Pretty neat feature actually. The only car that I've seen so far using something similar is the F103 TRF. Although there the approach is different and the angle of the T-bar itself is limited by screws MA2 in the battery tray : Btw - if I am correct less body roll will give more oversteer... And more allowable angle will shift the characteristic to understeer. Another edit of course - I think the official term for it is tweaking... |
"Tweak" is also linked to coffee, a small mountain town, & underpants gnomes (If you've seen that episode?)
Why would one want to attach the extra plastic bits though when there are perfectly fine holes there already that will match the shape of the chassis better and that would also be a more stable connection?
