I finally found one, within reach too. While the body may have seen some better days the chassis is there and in good shape. The radio box has a crack around ine of the mounting holes. Someone in the past changed the steering linkage, and the wheels and tires I believe. Either way its a good base for a project. I might sell my Fox now...
I wanted a set of these buggy champ wheels and tires on my re-re grasshopper, so I will likely be doing a switch around with the Grasshopper and the Sand Scorcher Thanks for lookingn, cheers! |
That's a nice find - the wheelarches on the original bodies is a much nicer shape than every variant that's come since, and the chassis looks like it'll clean up nicely.
The steering rod ends looks to be vintage Parma replacements, but the studding (allthread) looks suspiciously brand new. The damage to the body looks minimal & nothing a bit of glue, filler & sanding wouldn't fix It does look like someone has systematically stripped the body of almost all the detail parts though |
Very nice find.
Yep, I will be repairing this body, and I will likely order a repro body for the pieces, or use that body to run it and while its in the shelf I can put the original on.
sorry. No original ss body for me
CRP had several different steering rod kits with full threaded rods, as well as those same ball ends. Here's an example: |
Last edit: by TommieG.
What is shapeways? Sounds interesting. There is still one doorhandle on it, it would just have to be mirrored |
