@waterbok
I got Tamiya 18T Pinion Gear for 540 Motor (#9805997). I reckon this will not work and I should get the RRP metric mod .6? I just chatted with Hobby King technical support guru and he told me that I should be able to run my Egress with 18T pinion gear and use the Turnigy TrackStar Waterproof 1/10 Power System 5200kv Brushless Motor 80A ESC. Yep the 5200kv.... he told me that it will not damage my Egress's drive shaft. I double asked him to confirm. So should I go with the 5200kv rather than 3520kv? Thanks |
Last edit: by bigwig.
If you can afford it avoid these cheap Chinese brushless gear & lipo batteries. They're much slower, far less reliable & have a shorter lifespan. Unless you don't mind being beaten by anyone running gear from the more reputable brands. My other car is a Tamiya - bumper sticker on my van
Was told the Trackstar was better quality when getting a combo for the Losi 8ight & it was really easy to change settings with the program card. It's the only hassle with Tekin is that you have to use a computer to change any settings on the speed controller. Although it looks pretty cool doing so & it's much better than having to press buttons on the side of the ESC in the correct frequency to adjust things.
Thanks.
My egress is 2013 but I guess it still based on 80's design. lol I will just stick with a moderate brushless motor for now and take it from there. Thanks again for everyone's inputs.
The following user(s) Liked this: rcmadkiwi
