nice find, bit blueisch
I got me the 53109 Turnbuckle Shaft Set and 53110 6 mm Ball Adjuster Set instead was inspired by this guy langlotz I discovered after two years that the "ugly" dampers I got with my second hand CR01 were vintage 53037 Hi-Cap Dampers (Short) one just has to love this fisch |
Great reference page and build - and dampers btw.
Having the carbon chassis set and lightweight diffs is just brilliant. I found the matching turnbuckle set (53110) at some point too - with some other cool (and rare) parts. But I think I'll leave the blue ones NIP for now, having chosen TRF adjusters and 3racing titanium turnbuckles. Got a carbon damper stay so only item of the ones above I still have is the torque splitter... great one though. |
Ja the torque splitter is nice too, have both of them one in my blazing star (diff splitter) and one in my manta ray (the manta one)
you can notice a difference when turning the wheels, the manta splitter you feel the front gear diff still works with the otherone its just loose. The dampers were a nice discovery, got the Aluminium Pressure Plate Set too these were in a bashed up df-01 chassis I bought for 20 |
Is the first splitter (one way diff unit) the TA03 item?
Should be interesting to see the difference between the two... That chassis with extras is a great find. Very cool hop ups. I bought a Manta Ray parts lot mostly for the aluminium shock towers. Thought I paid a bit too much when it arrived, looking at the state of the plastic parts. But then I discovered a ball diff, TF hardened main drive shaft and Thunder Shot dogbones. Those were some unexpected surprises... Love to see that build thread of yours! |
I've checked those torque splitters before, how do they actually work?
My Projects:
There's quite a bit to it if you'd want to describe the whole process...
But I think what it basically does is cut off the feedback from the wheels that goes back to the rear. There is a one way bearing inside that enables this. It will then be easier to do short turns and the rolling resistance in general is lowered.
The following user(s) Liked this: Louisbaby
