Some of you may have noticed already, but this is to let you all know that I'm planning to do some smaller changes to TB.
Both changes needs to be done because of maintenance issues, the software used is no longer updated/supported. Both affected sections has been marked with text informing on the coming changes. The PM system will be replaced with a new one. The goal is to migrate all messages from the current system to the new one. In case that fails, you must make sure that you are not storing any invaluable information in the TB PMs. (I'll be surprised if you do!) The Trades section (on the main menu) will disappear. It's always been an addition to the Forum's Trades section, and I've decided to remove it entirely. From now on, just use the Forums: tamiyabase.com/...es-section The changes will happen when I have the time and without further notice. -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
The following user(s) Liked this: caprinut, stingray-63, AndyAus, 1972 LeMansGT Jim, quattrokid, EddyCH, GToddC5
