Re: Slop free DF-01 tub steering - plus TF undercowl! 14 years 1 month ago #12957
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
Hey guys, do you read this ad the same as I do?
Inner diameter is 4mm
Total width 5.4mm
Length 8.1mm 6mm
Thanks! :)
Aha! 0.7 is the pitch, not the wall diameter. :whistle:
That may open some possibilities!
Altough I am thinking about more radical dremeling and putting on the original GPM steering mounts :
Screwed down from beneath the chassis... :huh:
Re: Slop free DF-01 tub steering - plus TF undercowl! 14 years 1 month ago #12978
  • Edou
  • Hopping Mad
  • Hopping Mad
After some brainstorming and impatience (not having 2K glue, thinner or helicoils in stock) I went for the low tech approach.
Filling up the holes with CA glue, put in a used king pin and make sure it's straight, let dry and take out the screw...
Seems to be a temporary solution that works quite well.
I'll update later with something prettier though.
Re: DF-01 bathtub steering and undercowl mods 14 years 1 month ago #12992
  • Edou
  • Hopping Mad
  • Hopping Mad
M4 helicoils ordered on eBay. Let's see if I can make something more technically acceptable. :)
Re: DF-01 bathtub steering and undercowl mods 14 years 1 month ago #13289
  • Edou
  • Hopping Mad
  • Hopping Mad
Not an easy fix but I hope I can get it done...
I need to take quite a bit of "flesh" from the holes for them to fit. :unsure:
To be continued...
Btw - I already murdered two of them. :whistle:
Re: DF-01 bathtub steering and undercowl mods 14 years 1 month ago #13299
  • Edou
  • Hopping Mad
  • Hopping Mad
One side glued in and the other one drying - looks like it's holding up. :)
Re: DF-01 bathtub steering and undercowl mods 14 years 1 month ago #13303
  • Edou
  • Hopping Mad
  • Hopping Mad
Yes, it works! Steering parts refitted :
:cheer:
Re: DF-01 bathtub steering and undercowl mods 14 years 1 month ago #13304
:cheer:
Looking good :y:
Re: DF-01 bathtub steering and undercowl mods 14 years 1 month ago #13307
  • Edou
  • Hopping Mad
  • Hopping Mad
Thanks, I'm quite happy with the end result. Feels solid. But most of all - slop free! :)
Only wiggle room that's left comes from the servo itself...
Just gotta score a nice blue servo horn some time to top it off.
B)
One more tech detail - the right steering arm (left for the viewer) barely has any clearance on top.
It's moving smoothly now but I've assembled it a bit too high in the past, as can bee seen by the slight scuff marks :
That is why the ball ends cannot stick out and I put on some blue spacers :
Looks like it was meant to be like that. :cheer:
One more update coming - the fitting of the undercowl...
Re: DF-01 bathtub steering and undercowl mods 14 years 1 month ago #13313
  • Edou
  • Hopping Mad
  • Hopping Mad
One more after this one, that is... :whistle:
I think it could be justified to call this straight :
Re: DF-01 bathtub steering and undercowl mods 14 years 1 month ago #13316
Super work there, looks like it was made that way originally :)
You could have fooled me anyways :lol:
Cheers, Bram
Restoring Countach 58005
Restoring 58015 RR
Restoring 58098 F40
Restoring Audi Quattro rally
Restoring Mk.1 Sand Scorcher
Restoring Porsche 936
Time to create page: 0.180 seconds
