Boomerang 6 years 6 months ago #59361
Hi all
Please don't laugh.
I've just joined. I was into Tamiya cars in the 90's and recently bought an immaculate pair of cars - a vintage frog and boomerang, which my son and I have had a lot of fun with. However yesterday the boomerang (with new electrics professionally installed ) ended up in the sea! I fished it out with a boat hook and hosed it with tap water. Not good news, I know. Is there any hope for the boomerang? Should I get all the electrics replaced again? Don't want to bin it!
Any thoughts would be welcome.
Many thanks
Last edit: by Duncan.
Boomerang 6 years 6 months ago #59362
Welcome on board. You can maybe save your electro. Put all in rice during some days and try your system. If it works, dude if not, you would need a new receiver. Generally servos are waterproof.
Boomerang 6 years 6 months ago #59363
You need to rinse in clear water before drying to avoid oxydation.
Boomerang 6 years 6 months ago #59364
Thanks very much indeed for this help
Boomerang 6 years 6 months ago #59365
You're welcome duncan
Boomerang 6 years 6 months ago #59367
If it was actually submerged in salt water for any period of time, there is a good chance your electronics are done. Did it have any function at all when it came out or was the power totally dead? You can try drying and cleaning as previously recommended. It just might work, but probably not. I drove my E-Revo into the sea long ago and fried the electronics. The salt will rust the bearings (if you have ball bearings) so you'll want to clean those really well. The motor will probably survive if you clean it up and lubricate with some WD-40. If you tell us what kind of ESC and servo you have, we can advise if those are more or less likely to survive.
Last edit: by blakbird.
Boomerang 6 years 6 months ago #59369
Thanks Blakbird,
Yes, totally dead, although the motor works when I briefly put a battery to the wires...
All a bit depressing - she spent around 10 minutes on the Solent seabed!
The receiver is an Acoms ARE-227 and a Tamiya TEU-104BK
Keen to get it fired up again!
Boomerang 6 years 6 months ago #59370
OK, thanks for the information.
  • Motor: Assuming it is a stock silver can motor, if it is not rotating with a direct battery connection, then it is seized. This motor does not use ball bearings so those can't be rusted, but it has a sealed can that can't be opened. All you can do it spray in some WD-40 (or equivalent) and see if you can get it spinning again. I would guess you can probably get it working smoothly again.
  • ESC: The TEU-104BK is not waterproof, but I've had good luck reviving them after water contact. Open up the case and dry up any water with rice, then brush off any oxidation. It just might work.
  • Receiver: If my research is right, that's a very old AM receiver that's certainly not waterproof. Almost certainly fried. We can recommend some cheap modern radio systems if you like.
  • Servo: Still need to know what kind of servo you have.
Boomerang 6 years 6 months ago #59373
The ARE rx is not waterproof. But easy to open. One of mine took a bath several years ago. It still works fine. ( The m1025 hummer doesn't float :D )
