40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67045
Impressive kit - it really is a Beetle under those flat body panels :blink: :D
I didn't know how much I needed one of these until I saw your build, so thanks for that :whistle: ;) Could you please measure the wheelbase & track width?
I know Tamiya make 1:35 & 1:48 versions, plus a 1:16 RC version, but it seems like they missed a trick not making a 1:12 or 1:10 RC kit in the "vintage" era - the XR311/Cheetah chassis would have been a bit odd but not totally horrible (at least it's rear engine, RWD), or more obviously the SRB chassis - a detailed styrene body would work on either, with an almost full interior on the XR311 or partial/waterline interior on the SRB ... they could have made a military one (probably Afrika Korps box art rather than "Western Front"?), and civilian Thing/Trekker (in Sunshine Yellow) versions.
Probably should be careful what I wish for, Tamiya may read this & decide what we need is a vacform, top up Kubelwagen body on an M-07 chassis :S
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67047
Thanks Jonny for the title. I can't modify them.
tamiya did a rc 1/14 or 1/16 version. And a big scale version to.
Wheelebase is 27cm wide track approx 16cm centre rim to centre rim (rear).
I knew this kit from Richard. (Caprinut) .
Very detailed with 4 different decos. Same the roof is in web and able to move. Openable doors and sold with a mg42.
The new item of the kit has more details with photoetched parts.
Don't talk about it sure that tamiya will sale one.... 😁😁
The following user(s) Liked this: Jonny Retro, jord001
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67048
I am sure that a 4wd pilot could be installed inside. ;)
A "fritz" helmet is in the kit. I will try it on one of my head.
Last edit: by stingray-63.
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67054
error in the manual.... Front rims would be mounted before like inside sides. Now it's correct.
My friends real kubel picts weren't enough detailed.
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67055
This kubel is your fault richard. I didn't know that revell does a so big scale.
one of my vw engine should be under a beetle body but I'm not still decided to cut my only body of my mf01x. And the chassis has a too big back to accept the motor.
Hehe, should I point you to more stuff??
Revel did several large scale models, but they are getting rare. Among them are 1:8 street rod. Me want
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67057
I saw them a long time ago at my hobbyshop. 2 or 3 hotrods.
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67059
... comparable measurements on the SRB chassis are 250mm & 165mm ...
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67060
Oooohhhhhhh Jonny ! That smells good. I wanted copy your srb holiday buggy but still miss some spares. You need to build a kubelwagen. The kit is not so expensive for the size compared to a tamiya one and is good quality.
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67062
Looking good :y: B)
It's very tempting, the "old" version can be had here at around 100GBP, compared to 190 GBP for the "new" :blink:
I'm more interested in the later civillian "Thing", which although superficially the same has many different features - fewer pressed ribs, different shaped doors (the front ones also being conventionally hinged), square wheelarches, flatter frunk/bonnet & bigger nose, no doubt lots of other stuff too.
I think it would be easier to build a body from scratch than modify a Revell kit, and as I have other projects on the go it's going to have to just sit on the "ideas" list for the time being.
40 years / 1:9 Revell VW Kubelwagen Build 5 years 4 months ago #67063
Yeahhh a 181 is a civilian version. More squared.....
Time to create page: 0.201 seconds
