old KO digiace radiogears 11 years 1 month ago #35521
I found these things in a mess and I would like to have some infos on. I maybe have the transmitter a old gold alloy one but unsure that it is the good one. If somebody has infos like period, picts etc.... Thanks a lot
The following user(s) Liked this: TommieG
old KO digiace radiogears 11 years 1 month ago #35609
:blush: I found in my mess the aloy transmitter I said upper. I was sure that it was a futaba one, but pretty surprise it is the transmitter which run with the servos and the receiver :woohoo: .
a last small question, somebody knows the period where they are from?
Cheers Flo
I think that they will be on the RALT F2 or maybe better on my mardave gp f1??? :dry:
old KO digiace radiogears 11 years 1 month ago #35610
:) That's done.
The KO is now installed in the RALT.
old KO digiace radiogears 11 years 1 month ago #35620
I would say around 1980.
old KO digiace radiogears 11 years 1 month ago #35622
Thank you Tommie :y:
old KO digiace radiogears 11 years 1 month ago #35623
I found this page on 1970s multichannel radio gear - www.vrhc.co.uk/...1970's.htm - badge size/position suggests it's later than 1971 when that set was first introduced - but probably not as late as 1978 when the TX gained a dual rate switch. 1980 sounds a little bit late to me :)
It looks right at home in that chassis though :y:
old KO digiace radiogears 11 years 1 month ago #35625
:woohoo: Thanks Jonny. I' glad that this mount is coherent. youpi!
Time to create page: 0.169 seconds
