Hi,
I've bought two more or less complete Egress wrecks lately, and one of them came without the lower steel front shock mounts (BF8 and BF9), and with a front shock tower that I can't identify. The second one came with the original Egress tower and BF8/BF9. I have checked the manuals for all Avante-class buggies (Avante, Vanquish, Egress and Avante 2001) and none of the uses a front shock tower like that. Anyone who knows what it is? Original to the left, and the unidentified tower to the right. |
Last edit: by TommieG.
Holy macaroni! I managed to silence you!
PS. the tower fits the Egress if the lower damper mount is fitted "avante style", but not when using the Egress specific BF8/BF9 metal brackets. Was there ever a hi-cap damper upgrade kit for the Avante? Could this be a part of such a kit? |
Yep, you got us there, for now..
Is it just me (or the picture) or is the bracket to the right slightly unproportional ? Can it be home made? Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
No, it's completely symmetrical (I have measured it every possible way with a digital caliper), and has the same weave as the Egress tower. If it's home made, it's a darn good job. I will with 99% certainty say it's factory made, and with the same weave as the Egress, it "must" be Tamiya-made....
Phew...
Found it... the small shock tower is part of the Hi-Cap Mini option part 53036. I believe the tower is used when mounting Hi-caps to the Avante, but I'm not sure. tamiyabase.com/...Itemid=775 Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
Wow, thanks! So I was on the right track, then! |
Yes, that was one of my thoughts as well. But studying it, it became clear that it couldn't have been reshaped. |
