The only difference between the RM6 and RM7 are the body posts.
RM6 is supposed to have white plastic body posts with slightly different shape, and the RM7 has black plastic. RM5 has aluminium front body posts, and black plastic rear. There are other differences between RM5 and RM6/7 as well. RM5 RM6 RM7 Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
Correct, there is a extra pair of Upper Deck Posts on RM6&7, but they should be black plastic.
The silver Alloy posts are from the RM5.
Here are some picts of my mk5. I am sure that it was not modified. When I received it from my friend, the chassis was missing. I bought one on the bay. Are these front centre posts hop ups or an evolution of the MK5? |
I have moved the RM Mk.5, 6, 7 identifications to a new thread, so we don't interfere with Jonny's Original Body build
Your chassis looks like it started life as a Mk.5 (because of the FRP cross bar for the rear "damper") The upper plate would then have no holes for the centre posts. The new lower chassis plate you got would be from a Mk. 6 or 7, if it had the holes for the centre posts. The metal chassis posts you have are likely from an Avante, Avante 2001 or Egress: If you compare the two metal chassis post you have, you will probably find that the one with three grooves is ~0,5 mm shorter than the original Mk.5 chassis post. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
