So I measured everything up for you, If you use the standard battery settings for this model, you can fit a battery that measures 130mm long X 25mm high 46mm wide. If you remove the guide/restrictors you can put one that is 49mm wide
Most suppliers will list the battery dimensions in the description. If you can't fix it with a hammer, you've got an electrical problem mate
