Hi,
I bought my sons Hornet from Wonderland Models, and it's been a good 5 months with a few replacements etc. Now the car has stopped reversing. It's the ESC, a Tamiya tble-02s. I plugged the steering servo into the throttle channel and ruled out everything else. I reversed the motor wiring and ruled out physical problems, so its the ESC. I've tried the top end adjustment, nothing. I've tried the "release on red" - nothing. Is there an easy solution to this problem? Thanks, Andy |
Hi Andy
You can swap the esc by a chinese one. For 6€ you can find one easy to use. You can find them on evay
The following user(s) Liked this: AndySuth
Sure! It's better.
Not sure as I don't have the manual beside me atm, but I think there is an option to disable reverse (it used to be a setting used for races), try or check this setting.
Check the normal/reverse switch for that channel on the TX?
