Hotshot Street Tires 5 years 4 months ago #67012
Hi I’m looking for Hotshot street tires. The stock tires tend to have poor traction on the pavement. I have a 12mm hex conversion kit and looking for tires that can fit the old rims. Or a new set of tires and rims that are the same or similar size and width as the stock hotshot tire.
Hotshot Street Tires 5 years 4 months ago #67013
You could use TGX wheeles
Hotshot Street Tires 5 years 4 months ago #67025
Hotshot wheels are 2".
Optima Mid is one that use that size if you can find any.
Used to be options for 2" foam tires, but they are getting a bit harder to come by as everything seems to be 2.2 or larger these days.
Depending on your location, you could look at the selection of wheels at Modelsport.
I bet you can fit 1.9 tires on with a bit work, like HPI vintage racing tyre 26mm #4793 and #4797 for the rear. They might need foams to prevent the tire to collaps in the center as you are streching a smaller tire onto the slightly bigger wheel than it is intended for.
Hotshot Street Tires 5 years 4 months ago #67026
I recently got some HSP 2.2" wheels and tyres;
Front 06008, 06009
Rear 06024, 06025
Also some Traxxas wheels;
Front TRX-4 Sport 1.9" #8178
Rear TRX-4 Sport 2.2" #8180
Time to create page: 0.116 seconds
