please keep the postings to a minimum in this thread, I want only the drawings and maybe some pictures in here, and update these in between work in progress.
any comments please put them in the discussion thread. |
Very nice work men |
Waterbok, your effort here has resulted in an upgrade of your Tech Tip Award, now, it's "Gold"
-Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Edou said we don't need it.... Done them before, they're easy enough, but it would be nice to have the proper dimensions to work to (I just made mine up as I went...)
Much prefer my front body mount to Tamiya's one! Just wondering what could be done with the servo mounts to make them look the same - it would be possible to do similar posts, but mill flats on the fronts to land the servo on, but it would mean the servo sat a couple of mm back from where it's supposed to be, dunno if that matters? I think the parallel part of my bases needs to be tweaked shorter, they look a bit thick to me (From memory they were 1.5mm rather than the 2mm specified, the ones I measured were about 1mm) - I think the shape would then look much more like the originals.
