The last week or so I have been busy with a digitizing probe for my CNC. I had trouble to line up the 3 pins on the inside that actually triggers the probe. I was at whits end when a thought popped into my head. Why make something Tamiya already did! I used the differential X section from a pile of old TA03 parts I have lying around. This replaced a part that took me hours to make just to have it fail!
The previous attempt. Looks fine, but is badly miss aligned. This causes it too get stuck and the digitizing stops. The machine would keep running, but it won't pick up any more points.
This is the assembled probe. And yes that is a Tamiya 3mm ball on the tip!
After a bit of re-machining and threading the Tamiya part this is the result.
Now I need to get new bearing balls from a bicycle and I can wire this puppy up again |
Great engineering by both Tamiya and you
The following user(s) Liked this: Kermit
It usually takes me double the time to do things like this as I have no training for this, but I enjoy the challenge. The probe will hopefully be used for my most ambitious project ever. I want to re create the Porsche 959 mold. Don't know if I will ever pull it off, but worth a try.
