you may have read my hsp warhead brushless build and saw that i have made an rc switch from an old servo
you all will have an old servo with busted gears lying around the place i have a board design for kits so it will be easy to make rc switch ( click to view in 3D ) should i make these kits and sell them? i just designed this in a few minutes the next versions will be smaller i will need some money to get started as well i might do this like a kickstarter thingy |
Last edit: by zephyrin.
I think it's a great initiative.
A while back I looked around for a simple switch module for the lights on my third transmitter channel... But backed away because of the prices at the basic level even (several dozens of euros). If you can make it more affordable, I'd be very interested. In any case, I can really appreciate the clever stuff you've been into.
The following user(s) Liked this: zephyrin
they would bee good to have im just thinking of the prices
10 boards $15ish with postage caps $3 ish diodes $3ish headers $2ish so i would sell the kits for around $5 update!!!!!!!!!!!!!!! i checked the prices caps + diodes $3 don't know the postage board + header + postage $15 ish |
UPDATED VERSION
i couldn't find cheap regulators so i added a pot so you can adjust it eagleU01.zip ( click to view in 3D ) |
a great idea, good luck with it. You can also use a 4013 chip (example here - www.laureanno.c...tekmod.htm) if you don't have any old servos available, but you need some other components so its not as cost effective,
regards Johann |
agreed, using a servo is much easier. Also what I find odd is the ic chip used in the servo is quite often dearer to buy than a servo. I tend to go and make it all only because I like to tinker (and I don't have to make many!),
regards Johann |
cool
i will keep tweaking the board design, when i get it perfect i will get some sent off and made then i will sell kits the prices might be like this:
with the servo ones i might use this servo not sure if it has enough power though |
slight update
if you have any sugestions tell me i might get rid of one of the diodes, my one works fine with only one |
