I wanted to show a setup I build for measuring rpm at no load with a cheap china laser rpm meter.
I used a pinion I didn’t need and pressed it into a small disc I made on my lathe. The laser rpm meter is from Banggood And I use a charger that has voltage out for running the motor up to 7v E voila dynatech does approx 21000 Finally able to compare some of the motors I collected. Also makes it easy to compare forward and reverse rpm to check if timing is zero or set in the right direction. Also handy to check if rpm of my record player running ok. |
How does the Laser Tachometer work?
Do you have a mark on the flywheel that's detected by the laser? Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Awesome Sander.
Your idea is wonderfull. |
I had no idea this sort of meter had got so affordable - nice work in putting it together
What rpm did you get at 7.2V, i.e. how close was it to the 22k rpm Tamiya claim for the motor? |
Ok, now that's very cool!!
Might need to look for one myself for the same reason I have always been curious about some of the vintage motors I have, some just have no info available and it would be good to check the claims on the ones that do.....very cool indeed From somewhere out in the wilds of central Ontario.
