I'll be buying some as well, I know Jonny could use the funds.
I don't think it would be fair for me to try and make a profit off the TamiyaBase.com name, but (pending larbut's approval) I'd imagine making a few for the TB regulars & getting postage costs & a contribution for materials would be ok? I'd prefer to do it in one batch rather than in dribs & drabs, and in a very limited range of colours and sizes. I'll do a little testing to see how small they can go, the upper limit would be what can go in an A4 boardback envelope.
I didn't think about do a profit. Only pay materials and the work.
Very ambitious cut (14+k nodes) tyring to replicate the Model Junction (still going BTW) carrier bag from the 80s ... some evidence of a 45 degree cut across it, or it might have been a scratch.
The layout is wrong but TBH i can't remember exactly what it should be ... probably Hornby, Scalextric & other logos too. Weeding was a pain, if there's a mk.2 (very dependent on finding the correct Letraset (?) font) I'll simplify the Hotshot portion a lot. Attachments:
Also been experimenting with TB text, these are in "Tamiyabase header green" in normal orientation for sticking to the outside of things, I also tried "mirrored" (for sticking to the inside of windscreens etc) and in plain white.
Sizes from top to bottom: 1x 568mm 1x 440mm 1x 325mm 2x 284mm 2x 244mm 3x 182mm 3x 150mm 120mm proved to be a pain to weed with a 50% fail rate, 90mm were impossible Likely costs & postage rates I'll work out later Attachments: |
Yeahhhhh.
check your blade angle, you get can 30, 45 and 60 degree blades. 30 Degree is better for small work, 60 degree is also good for chrome, reflective and tougher vinyls. Also for tiny stuff, I do a kind of reverse weed sometimes. After cutting I apply the application tape and then weed away what I don't want, with the app tape holding the tiny lettering in place.
The epoxy on the carriage clamp failed so I've made my own, there being no replacement available for this model (not even 3D printed) ... I had planned to file one from solid alumnium after making a styrene sheet prototype, but TBH that's working so well I don't think I'll bother - the main difference being on my version, the clamping force is at the right angle rather than 45 degrees out
Attachments: |
Found a trick regarding the cleaning process. It's easier to transfer the whole thing before weeding than to transfer after the weeding... It may hugely decrease your failure rate on lower size elements... Now, that being said, it may also depend the quality of the cutter (I use a Silhouette Cameo 4). I buy kits to built and ru(i)n them
