Having had a DOA radio (at least dying in the weeks between it arriving and me using it … or maybe before
Apparently, servo testers are another thing I’ll have to add to my list of things I just can’t keep hold of/lose very easily – and the battery pack attached to them Add in needing to find batteries for the TX, and servos to test the RX & it can become really tedious. I thought if I put them all together on some sort of board (rather than in a dedicated tub I started by marking up a bit of 3mm styrene sheet for points to screw the servos to… predictably enough one of the threads failed immediately. I could helicoil all the holes, but I don’t plan to swap them out so a simple nut should add enough security. I had planned to have provision for 8 AA cells on the left hand edge, but the 14mm holes would have to touch to make it fit – so a more balanced 4 at each end of the servo array looks almost like I planned it Board in “stowed” position … the elastic band around the 4xAA holder cried freedom just before I took the photo Testing a used radio (with 4 channel TX, despite the 6 channel RX) … handles on the ends & some sort of hi-vis striping on the edge are a possibility Attachments: |
Nice.
I store such things in the yellow box storage you can see in the background of my workbench pictures. To make it a bit easier I have labeled one box for new AA batteries and another for half used ones. For me it made it a lot easier to find things. Before I had to rummage through all my stuff..
