Molotow Chrome 4 years 4 months ago #71843
Couple ques on the Molotow Chrome pens....
1. Safe to use over existing paint (in this case, Tamiya TS), assuming the paint has had plenty of time to cure?
2. Would you clear coat over the Molotow (assuming it's had the usual thousand days to cure), or best to clear coat first and then use the Molotow?
Cheers,
Molotow Chrome 4 years 4 months ago #71847
I use it directly and wait several days before touch it. No clear. It works on lexan and hard bodies
The following user(s) Liked this: Lemsko, Ducksnuts
Molotow Chrome 4 years 4 months ago #71848
I use it to like a chrome base for lights. For example on the lunchy body. After several hours, I apply red or orange translucid x26 x27 tam paints. That does the job
Molotow Chrome 4 years 4 months ago #71865
You can paint it directly, i put a gloss paint layer on 1st, color doesnt matter.
It loves to be applied in heavy layers compared to aluclad and other model chrome paints. I leave it alone at least 5 days before touching it again.
I tried several different clear coats to protect the chrome paint, but all turn the chrome surface into a silver one.
Comparism between new and old chrome (14month difference)
The following user(s) Liked this: stingray-63, Ducksnuts, mirrorman
Last edit: by Lemsko.
Molotow Chrome 4 years 4 months ago #71880
Thanks guys,
Just the answers i was looking for.
Cheers,
Molotow Chrome 4 years 4 months ago #71919
Couldn't be more right, if this was more versatile it would almost be perfect. I have also tried to clear over it to protect it, it doesnt work HA!
The following user(s) Liked this: stingray-63, Al, Lemsko, Ducksnuts
Molotow Chrome 3 years 1 month ago #76733
This paint material is actually very durable. I've only used it once but highly recommend it
geometry dash
The following user(s) Liked this: Lemsko, mirrorman
Molotow Chrome 3 years 1 month ago #76734
If you need to redo the job, the color wipes off easily with alcohol, even if the color is completly dried.
Molotow Chrome 3 years 1 month ago #76735
I can vouch for this product; I have used it some to restore plastic “chrome” plating on my diecast car models.
Time to create page: 0.243 seconds
