I have a weller with pen style solder. Very efficient. And I can replace the nose with different size
ones. 0 to 450 ° |
As my left hand got tendonitis this weekend I wanted to unload some work for my hand.
Enter my new mini drill. This cheap mini drill even has torque settings! 5 year guarantee for 28 dollars, can`t go wrong with that! I do own two mini drills, my favorite has a dead battery and the second one will not hold power over time. Only missing now is speed bits. All my similar handtools tips has either 3 or 4mm something shank instead of 1/4" fitting. (For example my Align 4 in 1 umbraco) Found out speed bits are more expensive than this mini drill. These was cheaper and plentyful before. 50 dollars for Traxxas speed bits is not worth it. |
Check your local hardware or car parts stores. I have a kit similar to this, and was under AUD50.
www.bunnings.co...t_p0115670 Has a 6mm (probably 1/4") shaft. Downside is don't have the long shafts like the RC stuff, but does have an extension piece. And smallest hex is 2mm, so no 1.5mm |
Bit the bullet and ordered a set of M-Drive ones online |
The following user(s) Liked this: stingray-63, Scanox
Attachments: |
Last edit: by stingray-63.
