Hey all,
I am trying to find a copy of the vintage Kyosho Outlaw Rampage (nitro) Stadium Truck instruction manual. Have tried many sites, however these only have the 'Pro' version which has a different chassis. Could anyone help with a link / scan. Thanks in advance! |
Can you post a pict of the chassis please. Kyosho made lot of cars on the same chassis. Is it the same as the zr1?
I have the Kyosho Outlaw Rampage Pro manual as a PDF-scan if you can use that?
You can find it in this list: tamiyabase.com/...nuals.html Edit: Sorry, I did not read your first post properly... Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
Hi again
www.sendspace.c...ANgvnIWHxg the link will download 2 pdf files I hope i helped. You see i also found time during the lockdown to "play" again Kind regards
The following user(s) Liked this: Daz_8
Thank you for the link.
I have now massaged the PDF's and uploaded the manual to the Downloads area. alex65 is credited as source of the file. Direkt link here Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
The following user(s) Liked this: stingray-63, Daz_8
