Tyre repair - cracks, tears and deformation 8 years 3 months ago #51062
I couldn’t decide where to put this topic, please do move it if there’s a more appropriate home.
I’ve had a poke around but can’t (surprisingly) find a topic on tyre repair.
Basically I have these tyres and am in a position that I need to repair them. Naturally I’m assuming they have sat in one position for a long time and deformed the cracked. They are a closed/sealed tyre so getting inside could be tricky, not impossible though.
Does anyone have any glue or purpose rubber glue tips. I have a “how it’s made” episode in mind where they remould tyres and use rubber glue to bond it.
Looking forward to your opinions and tips
Last edit: by Purple_rob.
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51064
What you are looking for was an Article by JR not a topic :) Check out the Articles tab top right of page for some great info :)
Here is the link to the specific tyre one :)
tamiyabase.com/...eservation
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51065
it's also a bit out of date ... things move on, big addition in the field is "Rubber Toughened" CA adhesive for gluing cracks & even cutting 'n' shutting tyres to make them smaller... I'd specfically recommend ZAP-RT for this.
IDK if there's an optimum place in the process for gluing, TBH I'd scrub it, glue it, then soak in glycerine as I would have thought the risk of glycerine contaminating the joint area was more that the risk of it attacking an already glued joint.
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51066
Somebody tried the blue glue for real tires repair? The vulcanisation glue ?
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51067
" TBH I'd scrub it, glue it, then soak in glycerine"
That's exactly what I thought. I think I'd apply the glycerine by hand so I can sparingly apply it around these fixed areas.
Then there the slight flattening on the cracked side. I may try inserting a foam tyre insert.
I'm going to look around for some products now, plus that recommendation.
Flo, ill look up that one too...
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51072
Tyres washed and started on one of the wheels... Luckily the wheels look pretty good.
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51073
I was thinking of other options for replacement tyres for this and found the RC4wd version ?
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51074
Alternatively, Getting down to your local toy barn and seeing if they have any tractors with suitable tyres? :)
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51083
Thanks Andy, the first ones look really quite good.
Although I must admin the thought of getting these ones to look good is quite exciting. I will try my best and see where I get. I think I am going to take all of these updates to a specific topic, Unless we can just change it to the Kyosho Datsun 4WD purple_rob topic :P
I have some updates to post on the project.
Tyre repair - cracks, tears and deformation 8 years 3 months ago #51094
Done :)
Time to create page: 0.234 seconds
