Hello all! So I have a vintage Acoms AP-201 radio and its missing the antenna that screws in. Does anyone know if vintage Futuba etc were the same size thread? I find many different brands but not many for Acoms an the ones I do find are in another country. This is my only vintage radio that has the screw in type antenna so I have nothing to compare it to, Thanks!
Futaba attack sr have cliped and no screw on. Maybe the sanwa dash saber antenna.
The following user(s) Liked this: tamiyakid80s
Most vintage antennas do fit.
The are either with internal threads or have external threads on them. Think they are M3 if memory serves my right. I can go and check what is on my Futaba Attack radios etc.
Futaba Attack R has internal threads (threads inside the antenna)
Sanwa Dash and Sanwa GC2200 has both eternal threads (threaded rod in the end of the antenna) That is what I have of old transmitters. Most AM antennas will fit I think, FM ones can be a bit thicker, at least the one I have which is a helicopter transmitter. Futaba and Sanwa ones is around 7mm thick. If you are lucky, your lhs might has some in stock..
So yes, a Futaba Attack 4 style antenna should work.
AP-201 has internal threads, so have the Attack 4.. My lhs has that style in stock www.elefun.no/p...spx?v=4008
Rather embarrassingly I no longer have a full perm of Acoms transmitters to check (just a couple each of the mk.2, mk.3, Technidrive, & the final 2.4Ghz stick sets)
hi if i was u i would just look one up on ebay right and just ask the seller least u know then what size
AERIAL ANTENNA FOR Acoms Techniplus AP-202 AP-201 ...
3mm thread and male connection and 7mm diameter to suit Acoms (Asahi) AP-202 and AP-201 Closed length 17cm, Extended
Last edit: by spannerman3.
I did find one on ebay, the external screw typpe, but its in the UK and Im in America. Takes 3 weeks or so and didnt want to wait that long. Thanks for your help!
Thanks! Much apprciated!!!
