Narrowing the re re Holiday Buggy 13 years 2 months ago #24373
  • stevieg
  • stevieg's Avatar Topic Author
  • Stomping Around
  • Stomping Around
Hi all,Just thought i would post a few shots of my w.i.p holiday buggy,im not sure what medication Tamiya were on at the time when they decided to plonk the sand rover and holiday bodies on a DT-02 chassis but the wheel width looks ridiculous,so out of scale.Anyway this is my attempt so far at narrowing the front and rear for a more scale look,so far so good.Up front i have cut down the original lower arms,used threaded rod and ball joints to make an adjustable top arm and am still at the design stage of the shock mounts.The original shock towers have been cut down and will hopefully still be used.
At the rear i have used TL-01 lower arms,cut down the original top arms,used TT-01 dog bones and Brat/Frog axle shafts and rear dampers.Im waiting on parts to arrive before i can progress and will post further shots later.
Narrowing the re re Holiday Buggy 13 years 2 months ago #24374
Nicely done :y: now that you have made it narrower, does it seem stretched?
Narrowing the re re Holiday Buggy 13 years 2 months ago #24401
  • stevieg
  • Stomping Around
  • Stomping Around
It doesn't look stretched,just more in proportion,like the original.
Narrowing the re re Holiday Buggy 13 years 2 months ago #24402
Nice
Narrowing the re re Holiday Buggy 13 years 2 months ago #24409
looks much better!
Narrowing the re re Holiday Buggy 13 years 2 months ago #24437
Some excellent modifications there. B) :y:
Narrowing the re re Holiday Buggy 13 years 1 month ago #24582
  • stevieg
  • Stomping Around
  • Stomping Around
O.k,the rest of the parts arrived and i have finished the mods.Up front the dampers were mounted using Frog/Brat front lower shock mounts and at the top a square section of plastic was trimmed to fit inbetween the original cut down shock mounts,a triangular piece of metal was also fitted for renforcement.The front body mount fitted nicely on top of this and i also lowered the front of the body at the same time.The shocks are after market units i bought a whileback from Jazhobby i think,not too sure.
Last edit: by stevieg.
Narrowing the re re Holiday Buggy 13 years 1 month ago #24584
  • stevieg
  • Stomping Around
  • Stomping Around
I used TT-01 dog bones which are too thick to slide into the brat drive shaft slot and had to shaved down considerably to fit leaving them perhaps a little too weak,does anyone know of a slim metal dog bone 30mm pin to pin i could use instead?
Narrowing the re re Holiday Buggy 13 years 1 month ago #24586
Tamiya 9805503 for M chassis maybe?
You can fit Grasshopper rear springs on the Frog shocks if the setup turns out to be too hard (JR (c) 2013)...
Narrowing the re re Holiday Buggy 13 years 1 month ago #24602
  • stevieg
  • Stomping Around
  • Stomping Around
Thanks Edou,they look something like,need to get a measurement on them.
