In other words a Lunchbox with new body...
The Pajero was called Montero in Spain, USA, etc... Specs from Tamiyausa.com:
-Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Any pictures? With that description, surely it's re-re of the
58044 Pajero
No pictures yet.
The description says Luchbox chassis, i.e. not rerelease in my perspective. We can only hope the body is the same as the 58044. -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
I guess it could go either way ... but I think "uses the same chassis components as the lunchbox" is a fair description of the vintage Pajero - same rolling rear axle, same front wishbones, same bumper, slightly different wheelie bar, and the chassis tub wasn't modified that much from the Pajero to the LB/Pumpkin ...
True, but I doubt Tamiya will make the Pajero chassi as long as they have the Lunchbox chassis available. Time will tell -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
I guess I was being a bit optimistic - "115mm tyres" sounds like the balloons on the Lunchbox
At least it'll be a hard body - although I'm sure it'll be altered to suit the VLB/Pumpkin body mounts - and who knows what they'll do to the sponsor logos ... |
he he, sorry but I doubt it.
If that was the "new Pajero" the vintage Tamiya world would go nuts -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
A side note:
I am baffeled by the speculation going on in other Forums regarding this new model from Tamiya. Quite a few of the posters has not even read what Tamiyausa writes on theitr site. So the speculation goes lexan/hard body, "hope the wheels are original", "Hope it is the original chassis", etc, etc. Come on! Read the specs.. Rant over -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
