Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67304
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft.Hi
I am going to purchase a MIP diff kit for my 2005 Frog Re-release #58354. Does the above "universal drive shaft kit" come in the kit, so no need to purchase this part when fitting the MIP?
Thank you
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67305
Hey there, The 2005 Frog comes with the dog bone type drive shafts but these still work with the MIP diff kit 😊
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67307
Thanks for reply.
To clarify no need to buy the additional universal drive shaft part as I can use the existing new style parts which come the 2005 re-re?
Regards
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67316
Thanks for reply.
Regards
Correct :)
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67317
Great.
One other question, do I need to change the gearing to the "diff gear set 9335026" with 16t pinion? Or again is that only applicable to the 80s model?
Thank you for your help.
Regards
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67321
If you are installing the MiP diff on the re-release Frog, you should not need any additional parts.
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67323
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67324
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67328
if your going to put a bigger motor in it YES UPGRADE T:O 53908 Tamiya Frog Assembly Universal Drive Shaft. YES UPGRADE from the normal dog bones
the normal dog bones will keep poping out so yes must upgrade ok
i would
upgrade anyway its just better if u do now with the bigger gear in then not do it i have this gear in my one and i upgraded my shafts same time
DO IT you will thank me later i know having to stop every 10 min to pop them back in its a pain in the neck
Last edit: by spannerman3.
Re: 53908 Tamiya Frog Assembly Universal Drive Shaft. 5 years 4 months ago #67329
Thanks 🙂
Time to create page: 0.156 seconds
