Hi Lars,
I noticed something not going right on your model pages. When you change to watch 50 at a time, it starts off from #26. Only when you go to the second page and then back again to the first 58001 appears... Edit - it seems to vary with the number of models you choose to be shown. Sometimes the list starts with 58006... |
Looks like this is not an issue anymore. Edit - Sorry, the bug is still there. I was looking at the wrong page. This is the one : www.tamiyabase....ducts.html Something goes wrong when you change the number of models shown. But only with the first time you do that... |
Hi Edou, This is a problem that I actually knew of, but had forgot... I have solved it now by a quick and dirty solution, by removing the option to select numer of items pr page... Not ideal, but the best I can do because of incompatible software... -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Thank you! Fixed now. -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
This is in the pipeline. It means I have to change out the complete Gallery system, but the new one will be much better. I have not started testing yet, so it may still take some time... -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
