Saw this on eBay looking a bit sorry for itself ... and very cheap
Rear tyres are very bald, rear shocks & fittings are missing, as are the gearbox pivot, "joint" and "joint holder" that allow a bit of rotation... but the plan is to spend as little as possible on it Decals & paint are very poor I'm sure this will amuse eddrick : possibly the worlds worst example of soldering. Not only does it look like pigeons did it ... ... it was a dry joint - note the hole where I pulled the wire out |
Hahaha yes it did! Even better that even after that amount of daubing it still wasn't stuck!
Shouldn't laugh really, it may have been a first ever attempt at soldering by someone who will eventually become a politician, salesman, teacher, doctor etc, or maybe by a horse (They struggle due to lack of fingers)
fIGHTER RX special edition Worse than my poorest car. If it was cheap it's a good piece for spares and the body can be used for the rookie rabbit Nice yoghourt paint |
Hmm yoghurt paint.... have you tasted it yet Jonny?
Wattle-n-daube (Chicken doo-doo & straw) kinda sprung into the mind there for a bit
I will test the fork and spoon painting. Maybe a new mode???
Jonny maybe is it a new ABS reinforcement method? |
Progress is not very fast on this, but I have made a little progress ...
Paint stripping (with UK recipe De-Solv-it Grafitti Remover) failed to get a lot of maky bits off... ... but 320 grit paper got it off... ... followed by a wet sand with 800 grit to get it more even: This left a few dents/scratches that needing sorting with filler (Squadron White Putty)... After sanding back it's ready for primer: Showing progress on white bodies is especially difficult ... you can expect several more near-identical shots with primer, more sanding, white paint, clear, etc ... :whistle; |
Probably the ugliest Tamiya car ever produced I see what you mean about poor handling two wheel drive basic buggies Jon one of these is too many
Last edit: by tamiya nut.
