Scratch build WR 2wd and 4wd chassis Carbon Dagger 12 years 1 month ago #30952
Took my hopped up WD apart and combined it with some old and new parts to make one carbon frame 4wd and two 2wd WR chassis.
1 WD
+ some parts
and a frame
make One
and Two
and Three
locked the rear diff on the 4WD and has 6mm ball nut for some beefier upper arms
now awaiting 10mm POM and 3mm aluminum for some diy dampermounts and suspension arms.
the carbon dampermounts are lower than the previous ally ones so have to think about different dampers.
custom battery mount (6mm carbon, 4mm brass tube and 3mm M3 wire and some bits and pieces)
the 2WD got 45T with 18 pinion thats fast enough for my little godbrat and his brother.
The following user(s) Liked this: Edou, stingray-63, AndyAus
Scratch build WR 2wd and 4wd chassis Carbon Dagger 12 years 1 month ago #31200
first delivery of pom plates was with different thickness.
the ebay seller solved it very quickly, now got double the amount so enough for testing.
also got the aluminium plates (same seller)
and took out the hacksaw and some files.
The following user(s) Liked this: Edou, AndyAus
Scratch build WR 2wd and 4wd chassis Carbon Dagger 12 years 1 month ago #31333
Slowly getting there. Been busy in the Cellar.
Bushings for the upper arms pivot
Mounted
Shocking
Mmm wheels funny
2 done, one more to go
Scratch build WR 2wd and 4wd chassis Carbon Dagger 12 years 1 month ago #31341
Nice handywork. Now for some anodisation. :) :y:
Scratch build WR 2wd and 4wd chassis Carbon Dagger 12 years 1 month ago #31342
Nah! like that rough look.
Bummpers
Different wheel setup
that setup should work as its only RWD
Scratch build WR 2wd and 4wd chassis Carbon Dagger 12 years 1 month ago #31343
Back to big wheels
Scratch build WR 2wd and 4wd chassis Carbon Dagger 11 years 11 months ago #31893
DIY lower arms, not as easy as it looks.
Scratch build WR 2wd and 4wd chassis Carbon Dagger 11 years 11 months ago #31894
I am afraid that if I put so much work into a car, I wouldn#t be able to give it away :P
Scratch build WR 2wd and 4wd chassis Carbon Dagger 11 years 11 months ago #31895
Thats not for the two give aways :blink: thats for my carbon 4wd dagger B)
Scratch build WR 2wd and 4wd chassis Carbon Dagger 11 years 11 months ago #31902
:laugh: I have the same matter Martin. I haven't the good tools and more I have 2 left hands :silly:
