I do intend on lowering the body by cutting the chassis and the body floor. I'll install the shorter shocks again, and redesign the shock towers. I'll just run the shocks softer to act more scale. This mod will hamper the crawling abilities because of reduced height and articulation, but will make it more of a trail vehicle.
I am going to use other tires, because the wild dagger rims and tires will be too big. My Projects:
I take it you've twigged that you'll need the shorter driveshafts to use with the shorter arms?
My Projects:
The dash came with the body, it have 3v light bulbs installed, but I'll install LEDs rather. My Projects:
