Hi, I have just built a box standard M05 SWB Mini Cooper - It's a lot of fun
Many Thanks |
Can't imagine that's part of the design.
But what about moving the ball connectors to the other hole in the knuckle? And you could have a look at the servo saver if you might be able to shorten the arm/lever. Could you show a picture maybe? |
Obvious things to check would be that there's an o-ring in each of the gearbox outdrives & that the steerign balljoint on each of the front knuckles is in the outermost hole
What Jonny said... he beat me to it!
If the gaps are bigger than O-ring thickness, you can chop up silicon fuel tubing & use that instead. I would also check how much steering lock there is, as if there's enough that the shafts can come out, there's a possibility they could also jam & break something, so adjust if need be, like Edou suggests. Finally, an obvious suggestion - are the front & rear shafts different lengths, & have you got the right ones in the right places?
