Wild "Wide" Willy 2 13 years 8 months ago #17998
:P
Jonny
I didn't know that your... was named willy... :huh: B) :whistle:
Last edit: by stingray-63.
Wild "Wide" Willy 2 13 years 8 months ago #17999
I'd always heard that the girth of a Willy was more important than the length ;)
Dammit! I've gotta get a Wild Willy just so I can join in on the jokes...
Wild "Wide" Willy 2 13 years 8 months ago #18000
Yep, I recommend you get you hands on a Willy ASAP :D
Wild "Wide" Willy 2 13 years 8 months ago #18004
Didn't we have a thread for the best quote's about ones Willy, think some of the above could be considered ;)
Have to get some work done on my Willy too so I can make his head turn, that project has been in a drawer for too long. :huh:
Wild "Wide" Willy 2 13 years 8 months ago #18008
Sounds painful or expensive.
Wild "Wide" Willy 2 13 years 8 months ago #18035
So I too went for some hot glue and put a socket screw in it, that did the trick and maybe have to use an o-ring to get the head facing in the right direction. :silly:
Beermeister, did you have to make a hole in your seat so your Willy would fit?
Wild "Wide" Willy 2 13 years 8 months ago #18036
No. I have a few 5 gram servos around. All I had to do was snap off one mounting ear and he fit right in.
Wild "Wide" Willy 2 13 years 8 months ago #18056
Beermeister, did you use a servo like the a HTX500 ? how did you put the 3mm thread on it.
Wild "Wide" Willy 2 13 years 8 months ago #18059
Used the Tower Pro version, looks to be the same dimensions. Used a 3x.5 bottom tap and a drop of epoxy. The top end of the screw got blue thread lock to keep his head from flopping or being too tight on the body.
Wild "Wide" Willy 2 13 years 8 months ago #18060
Yep looks the same, ordered some at HK and some servo reverser.
Time to create page: 0.125 seconds
