I like the Black brat, looks great. I'm surprised with the speed, considering you using 3S. It runs around the same speed as mine with the Sport tuned Black Can and a 5000mah 2S Lipo.
My Projects:
Thanks. 1200kv isn't much for speed. It's billed as a crawler motor. It has tons of torque. It used to pull around an 18 lb scaler with out missing a beat. I'm using it more for efficacy. After the vid I puttered around for another 30 minutes and checked the battery status and it still had 89% charge. |
Which is it - 2100 or 1200 kv? |
Ah, so "kv" means "revs/volt" (not kilovolts
30minutes running on 11% charge? |
It is officially written as Kv. So the "v" is just an indication it's about the velocity of motor constant K.
en.wikipedia.or..._constants The other kV means kilovolt of course... |
Nice grill |
