Hi all just bought a tamiya tt02b neo scorcher just wondering if anyone knows if other tamiya buggy bodies will fit this chassis as I am looking into getting another body for when I go thrashing and bashing with this buggy
Couldn't say much about a direct match, that would depend on the exact mounting holes.
But I'd dare to state you could get pretty much any 1/10 buggy shell to fit with some modification. My choice with be a Top Force or Dark Impact, they're cool and you wouldn't have to cut off the nose. Something more recent would probably be cheaper though. Edit - 266mm wheelbase seems to be a bit shorter than most but I don't think it would be much of an issue. A Blazing Star (same as Terra Conqueror) would be nice as well. And easier to find affordably. Specs of a DF-01 seem to come closest. |
If you measure the distance between body posts, I could compare exactly to a DF-01.
Although with that high front mounting point, you'll probably end of resorting to velcro on alternative shells. |
Reading a bit on Tamiyaclub and knowing Tamiya Inc, it might be easiest to wait until they release an alternative shell for it (shouldn't be too long) or get the same body just for bashing.
I do like to see a good mix and match (breaking some ground) for this chassis but it can be tricky. |
Ok thanks for your comments
