Just checked it again and it flash once green and went off Neil |
Is this post referring to mine or the other poster Neil |
Once green should be ok for brushed. Depending on the kind of car /gear box there sometimes isn't much of a brake effect. |
Ok so a little bit progress since last on, i followed that video on the first page and looks like was in brushless mode! so thats now changed to brushed motor.
So now what happens is when i pull stick in what would be reverse it goes forward and when i push stick forward i have nothing, so forward/reverse is wrong way round and i only have one of those fictions? does sound like anyone know lol? Grant |
ok so never tried that and yes, there is a small flick switch on the bottom of the controller on either side, so switched the lone located on the forward/reverse side
And now when i push forward it goes forward and pull reverse nothing, however when i try it a second time it now reverses, so i need to double use the stick to get the function, looks like i am getting closer but clearly not quite right yet lol |
That sounds like the brake function
That's what mine his doing but not much brake effect Neil |
There you go that's your Tamiya ESC, fwd, brake and only then reverse. |
