Blackfoot Extreme for the woman. 9 years 1 month ago #46003
Bought 2 beaten up Extremes last night for a steal. Started stripping one to see whats all wrong. Doesn't seem bad. Will do a build and upgrade to longer shocks and basic bearings and what not. Both came with teu101's and sport tuned motors.
Heres the lot as its standing:
Seems like they have been standing for a long time.
Sent from my iPhone using Tapatalk
Blackfoot Extreme for the woman. 9 years 1 month ago #46006
Nice find. :y:
And bodies look to be fresh...
Blackfoot Extreme for the woman. 9 years 1 month ago #46018
Thanx!
Plastic parts are soaking in a bucket of dishwasher solution and all metal parts have been cleaned in Turpentine. Gearbox parts are clean and awaiting bearings.
Had a look at the shock tower upgrade and noticed that they are for 105mm odd shocks. I would like to use CVA Shorts at 94mm. Took some dimensions and came up with the following:
I'm guessing the height at the moment. Please share your input!
Blackfoot Extreme for the woman. 9 years 1 month ago #46036
This is the GPM one no measurements but you can work your way from the holes.
I DIY them from 3mm alloy plate
The following user(s) Liked this: stingray-63, HugoBiermann
Blackfoot Extreme for the woman. 9 years 1 month ago #46040
Thats the plan yes.
Any possibility to get the distance in height between the stock mounting holes and the extended ones? just to clarify my drawing... And these plates are for 105mm shocks?
Blackfoot Extreme for the woman. 9 years 1 month ago #46042
Is this close enough?
Like I said, I want to use the 94mm CVA's.
Blackfoot Extreme for the woman. 9 years 1 month ago #46044
Messed about some more:
Extra width added for a more vertical position on the shock when mounted to the outside mounts on the arms. think this is as close as I will get to the ones on the net without measuring myself.
Sent this through for a laser cut quote:
Blackfoot Extreme for the woman. 9 years 1 month ago #46045
Dude!!! I like that :y:
Blackfoot Extreme for the woman. 9 years 1 month ago #46046
"...for the the woman"
? ::huh:
Blackfoot Extreme for the woman. 9 years 1 month ago #46047
The following user(s) Liked this: HugoBiermann
Time to create page: 0.120 seconds
