Blakbird's 58280 TXT-1 Build 6 years 11 months ago #57682
  • blakbird
  • Impressive Numbers
The TXT-1 is the third generation Tamiya monster truck following the 58065 Clod Buster from 1987 and the 58232 Juggernaut from 1999. The Juggernaut was replaced with a second version only a year later due to some significant design issues, but that apparently didn't resolve its reputation with consumers so the 58280 TXT-1 arrived in 2001. It shares many design aspects with the Juggernaut but has been differentiated enough to stand out to the market. The axles and transmission are from the Juggernaut, and the hubs and tires are from the Clod Buster. The aluminum side plates, steering system, and cantilevered suspension are new. The original Clod had axle mounted motors which are now inboard, but the steering has gone the other way. The prior chassis mounted steering servo is now located on the axle.
This is an accurate monster truck which is built much like the real thing. It has solid axles front and rear, four wheel drive, four wheel steering (optional), four link suspension, and sits on four enormous tractor tires. The central transmission is driven by dual 540 silver can motors, but there is an additional gearbox on each axle. This is one of the last models to use a mechanical speed controller. The kit comes with a pre-painted body as well as a clear body.
I was amazed at how complex the build of this model was. It's just some axles and links, right? The box has a massive pile of hardware and moving parts making it a real joy to build. I loved every minute of it. I love driving it as well. I replaced the MSC with a dual motor ESC and it drives like a dream: stable, powerful, and surprisingly agile. It has a much better appearance than the later TXT-2, in my opinion.
The TXT-1 comes in a massive box, most of which is occupied by the tires, side frames, and two copies of the body. The box is amazingly heavy and each time I withdrew another set of parts I became more excited about the build. I bought this set in an open box so I had to go through the whole inventory in detail and a handful of things were missing. There were some E-clips missing from a hardware bag, the wheel hexes were missing, and the drive shafts were from some other model and didn't fit.
This is as big a pile of parts I have ever seen for a Tamiya kit, and perhaps any kit. There are 8 labelled hardware bags, but they don't correspond to the build order. All the bags have to be opened right away because each step draws hardware from multiple bags. There are loads more bits of hardware that aren't in any of the 8 smaller bags and these included links, nylon gears, metal differential gears, bearings, drive shafts, and a myriad of other parts. Then there are a dozen or so plastic parts trees and it would be impossible to miss those tremendous wheels and tires.
The central gearbox is taken from the Juggernaut 2 although you can see "2001" molded into the housing which suggests it has been updated. If there is a difference, I can't find it. Even the instructions are identical. The shaft you see on the top in the first picture is the output shaft which goes both forward and aft. It is on the bottom in the second picture. There are two stages of gear reduction inside the gearbox at this point, and there will be a total of four once the motors are attached. You can see the very large pitch of the strong gears.
Addendum: I figured it out. The output shaft changed diameter from 5mm to 6mm between the Juggernaut and the TXT-1. This actually doesn't change the housing any because the bearing support is still 11mm. The bearings went from 11x5 to 11x6.
The dual motor system is also taken directly from the Juggernaut. The twin motors operate in parallel on a single spur gear. The gear pitch at this point in the drive train is smaller, but the gears get larger as the torque increases further downstream. There are a couple of metal heat sinks attached to the outside of the gearbox.
Blakbird's 58280 TXT-1 Build 6 years 11 months ago #57683
  • blakbird
The chassis is brand new. We'll start with the front and rear bumpers which act as intercostals between the frame rails. These are no mere C-channels, the frame rails are fully machined fittings. I was going to use the word "truss", but the areas are not triangular nor are the members pinned. The rocker arms for the cantilevered suspension pivot on the frame rails.
Here is the completed frame with the central gearbox installed. The gearbox serves as the primary cross member for the frame rails. The other cross members use aluminum tubes as spacers. The whole thing is very rigid at this point.
The axle housings are taken directly from the Juggernaut as well. Note the extra stage of bevel gear reduction inside the top of the housing. While most differential gears use a bevel ring gear, this one uses a spur. The massive straight cut teeth (the largest in the model) mate with another gear above for one last stage of gear reduction. That's six stages in total. All of the gears within the axle are metal.
Now the differentials fit inside the axle housings and mate to the integrated gearboxes. The gearbox covers are different than the Juggernaut because while that model has a chassis mounted servo and a servo saver inside the cover, the TXT-1 uses axle mounted servos which makes for much more direct and effective steering of those huge tires. Note the "2000" molded into the axles versus the "2001" on the cover.
Blakbird's 58280 TXT-1 Build 6 years 11 months ago #57684
  • blakbird
The steering hubs date all the way to the Clod Buster and still have that name molded into them. The suspension links, however, are brand new. The Clod used complex molded plastic links, the Jugg used simple plastic I-beams, and now we have tubular aluminum links. Eight links are used for the triangulated suspension and the four smaller links are pushrods for the shocks. There are also steering links front and back. That's a lot of links to build.
Now the axles can be attached to the frame using all those links resulting in a nearly completed chassis. The completed cantilevered suspension is seen clearly on the left. The oil filled shocks are located along the frame rails and driven by rocker arms. From below you can see how the pumpkins face down instead of out. The drive shafts are strong telescoping steel units. They look like they come from the Juggernaut but they don't. The inside diameter of the U-joint changed from 5mm to 6mm to match the larger transmission output shaft. I found this out the hard way because my kit had the wrong drive shafts which didn't fit.
The steering system is new for this model. The servo is mounted in the skid plate ahead of the axle and drives the right hand steering knuckle directly. The rear knuckles are locked per instructions, but can be built exactly like the front for four wheel steering. That's how I built it.
This plate contains the original mechanical speed controller system. This includes the MSC itself, a servo, a battery box, and a resistor. I'm not using any of this for my model but I wanted to include it anyway for historical accuracy. I used an old broken servo. For the real power system I used a dual motor ESC from Hobbywing as shown, and I'm also running of a 2s Li-Po battery making the whole thing pretty modern.
Blakbird's 58280 TXT-1 Build 6 years 11 months ago #57685
  • blakbird
The last bits of the chassis are the supports for the body posts and then installation of the wheels and tires. These are the tires from the original Clod Buster which differ from the rounded versions used only on the Juggernaut.
I'm quite glad that the body came pre-painted since I'm not sure how I would have managed the effects. There were still stickers to apply though. The picture on the right shows the lovely result.
I had previously built the 1/18 scale TLT-1 which is clearly intended to be a smaller copy of the TXT-1. That's not hard to see in this comparison photo.
Blakbird's 58280 TXT-1 Build 6 years 11 months ago #57686
  • blakbird
Although it's hard to beat the hard body of the original Clod Buster, I think this might be the best looking monster truck Tamiya has ever made. It's stance is just so imposing. The aluminum side plates look unbreakable (so far). I have no complaints about this one.
Blakbird's 58280 TXT-1 Build 6 years 11 months ago #57687
Nice massive monster truck.
Time to create page: 0.368 seconds
