The Frog was not what I expected. The 58041 Frog was, in a way, the first modern buggy. This may seem like a strange thing to say for a buggy released in 1983, so I'll have to clarify. All of the early Tamiya buggies were scale models of real vehicles. The ORV (Off Road Vehicle) chassis which was introduced in 1983 followed the same pattern. The first two vehicles to use it were a Subaru Brat and a Lancia 037. But then The Frog came along and it didn't really look like anything. It had big back tires and narrow front tires like plenty of real beach buggies, but the long thin chassis, huge wing, and massive front bumper didn't look like anything from the real world. These days, you would just say it looks like an R/C buggy because that's the basic concept that has been used ever since. Tamiya would release dozens more buggies in the upcoming years based purely on their own imagination, and often using animal names. The wing would usually feature some clever slogan (e.g. No Guts No Glory) and the driver would have a made up name as well (e.g. Glenn Morris). These names would get more silly over the years. It would take until 2005 for The Frog to be re-released as 58354. It is still basically the same as the original. Other than the use of modern electronics, the main change is in the stickers which have lost the logos of real racing companies and have been replaced with Tamiya imaginary versions.
The ORV chassis is pretty simple, but also pretty unusual. The front suspension is undamped but uses double wishbones. The rear uses independent trailing arms with aluminum, oil filled shocks. This is a 2WD buggy so all the weight is in the back including the simple gearbox and 540 motor. The chassis is a 2-piece space frame that is unique to the ORV. The chassis can't exactly be claimed to perform well, but given the age and simplicity I was pleasantly surprised. It actually does a really good job on mild terrain and small jumps. I began by saying the Frog was not I expected. For some reason I expected an entry level, bottom of the barrel starter set. I was probably thinking of The Grasshopper. The Frog is not that. The oil shocks and reasonably sophisticated suspension are much better than the Grasshopper so I'm glad to have been so wrong. The Frog comes in this lovely box with classic box art. The picture is almost the same as the original but the content of the stickers has been modified to remove the unlicensed company names. The picture on the right shows the arrangement of parts in the box. There are no blister packs, but everything is still nicely organized. There are not very many plastic parts in this model as evidenced by the handful of plastic trees shown to the left of my cutting mat. The rest of the parts are metal and are either bagged separately or with the hardware. The ORV chassis is often described as a "space frame" design. Rather than being an enclosed tub, the chassis uses an open framework. It is not a ladder frame like a truck because the rails are much more three dimensional with upper and lower rails canted downward toward the front. The chassis rails are ABS which, in my opinion, is too brittle for the primary structure of a buggy. Care must be taken not to over tighten fasteners or it will crack rather than strip. The gray frame comes in left and right halves as shown. They are then attached together with some cross members between as well as the battery hatch and front bulkhead which will support the suspension. After completing this single step, the chassis has already mostly assumed its final shape. The front suspension is fascinating. Both the upright and the C-hub are bent sheet metal. Since the C-hub attaches with only a single screw, it is subject to rotation which would change the caster angle. To prevent this, Tamiya includes the star washer shown which is supposed to lock them together. It seems to work pretty well. Note that the area around the holes on the mating parts is serrated to help grip the washer. On the right you can see the super short double wishbone suspension arms. Take note of those L-shaped cranks at the end of the arms. The crank on the lower arm will support the spring and the crank on the upper arm acts as a down stop. The steering knuckles are cast metal. The steel wires are radius arms which support the thrust loads on the front suspension to help protect the plastic arms. |
Now we'll delve into the way the front suspension is supported. There are no coil shocks. A stiff spring sits laterally inside the chassis frame and pushes a white plastic button as shown. This is retained by a metal C-channel which will also support the suspension arms.
From this front view you can see the end of the white button (look through the hole in the metal part) pushing against the crank on the lower suspension arm. This drives the arm down. As the suspension compresses, the button is driven inboard. This results in a compact sprung suspension with no damping. The picture on the right shows the completed from suspension. So far as I can tell, this is unchanged from the original Frog, though the front bumper has gotten stronger and wider. The Frog does not have an adjustable gear mesh, instead there are 3 sets of spurs and pinions included. The options are 52:16 (8.5:1), 50:18 (7.3:1), and 49:19 (6.7:1). The standard configuration is the one in the middle which is what I used. An aluminum gear locks inside the chosen spur with a wire locking ring as shown on the right next to the differential. The differential spur gear houses 3 metal spider gears with an output bevel to either side. This kit does not include ball bearings so I added them. The differential and spur gear then sit inside a narrow plastic gearbox housing which uses metal closeout plates as shown. In the picture on the right you can see the locking ring holding the aluminum gear in place. |
Here's the gearbox fully buttoned up. One flaw of this design is that the differential gears force the metal side plates outward. They are not very stiff so this deflection can be enough to cause gears to skip if the torque is high. On the right you can see the gearbox sandwiched between the frame halves. The drive cups are different than the originals. The re-re uses dog bone drive shafts, but the original shafts were hex drive and were not very durable.
The rubber boots shown slip over the dog bone drive shafts to keep contaminants out of the joints, and also to look cool. The rear trailing arms are shown on the right. Here the rear suspension has been assembled. The rear trailing arms pivot on the gearbox on the inboard side and on a sheet metal bracket on the outboard side. The plastic just rotates in the metal; there isn't any kind of bearing or even bushing for the suspension travel. The Frog uses nice aluminum oil filled dampers in the rear which have changed quite a bit from the originals. The original dampers had the o-rings and rod guide swaged into the end of the cylinder. They could therefore not be removed or replaced. There was also a floating volume compensation piston in the head end. The re-re dampers are more modern and traditional while retaining the outward appearance of the originals. They use a threaded rod end cap which locks the o-rings and a compressible bladder inside the head end. The complete exploded view is shown on the left. On the right you can see how the shocks are installed longitudinally and connect to a crank on the trailing arms. This keeps them very low and obviates the need for shock tower. |
A silver can is plenty of power for a buggy like this. The original Frog used 2 servos since it needed one for the mechanical speed controller, but the re-re uses only a steering servo with an ESC where the other servo would have gone. There's a big empty space behind that where the 4.8V receiver battery would have gone since it is no longer needed. I tucked the receiver down there out of the way which seems to have resulted in a pretty clean electronics installation. The main battery installs from below without the need to remove the body.
The wheels are a 3-piece clamping design similar to those first used on the Rough Rider. The basic idea goes all the way back to the XR311, but those mounted to the vehicle differently. The front wheels house bearings and the rear wheels slip directly over the drive pins. From the bottom you can see the metal under tray which protects the servos and the under slung battery. The completed rolling chassis. Note the very simple steering linkage with the servo saver driving the steering links directly. The rear wheels have some camber which will not change as the suspension compresses. The paint job at first seems very simple but is more complex than it looks. There is an obvious pink strip along the bottom, but an area of the windshield must also be masked to remain clear and the back deck beneath the wing must be black. After the paint is done the stickers can be applied and the spot lights attached. The wing attaches directly to the body which makes it very weak. The driver attaches to the chassis. Here's the completed Frog. One of the twin aerials would have been used as an actual antenna support originally, but here on the re-re they are just for show. I put them on because they are a component of the classic look of the Frog. On the right you can see a comparison with the smaller TamTech Gear version and the tiny Takara Tomy version.
