Dear Jonny (I figured I could direct my question directly to you, since you are anyhow replying to all of my questions
When sorting through the trees after my TD4 build, I figured that the L6 part was not used. The manual however does not state that it is not used (it's not marked in the greyish color). Also I OCR'd the online manual and could find no mention of the L6 part anywhere. So I conclude it is not used? What could it be for? Thanks and cheers MetalMaxx |
I have to read everything (it's in the job description), but I don't have to respond
The following user(s) Liked this: MetalMaxx
OK, had a chance to look - there's something about it that said "front body post" to me, but looking at a photo of the L part sprue showed it was tapered, and wedged shaped.
Does it fit on top of the front gearbox (L1) in place of part B5 (the front body post)? If that's the case, I reckon it was a cost saving measure, like the front body post was going to be plastic base, screw, aluminium turning, but 50 cents for the post + 1c for the screw X 20,000 kits < the cost to add something to the B sprue tooling. |
sounds plausible! checked it right away and the parts are interchangeable. No holes for the screws though in L6, but that is probably because they did not use it in the end.
Again, thanks so much. Really appreciate these kind of exchanges. |
