TAMIYA VW KÄFER M-06: Can I use a 380 Small Block on it ? 10 months 2 weeks ago #81516
  • TFan88
  • TFan88's Avatar Topic Author
  • No Guts No Glory!
  • No Guts No Glory!
The Standart 380 Motor.
It looks like there is no Motor Mount for a small block in the Partslist of the Instructions.
TAMIYA VW KÄFER M-06: Can I use a 380 Small Block on it ? 10 months 2 weeks ago #81517
The m06 is designed for the 540 . No interest to use a 380. If you want low speed you can use a crawler motor.
The following user(s) Liked this: TFan88
TAMIYA VW KÄFER M-06: Can I use a 380 Small Block on it ? 10 months 2 weeks ago #81521
As Flo said.
If you want slow speed, 35-55turn crawler motor should do it.
Hackmoto V2 45turn is a good cheap one.
I have not tried it, but maybe Grasshopper motor mount adapter might fit as it`s designeded to use 380 motor.
Seems the Grasshopper uses 9T pinion and Hornet (same gearbox but 540 motor) uses 18t pinion.
So you will need a pinion with 9 teeth less than the factory 540 motor uses when installing the 380 motor and mount.
On Grasshopper the pinion comes pre fitted so you will need another pinion if the M06 uses anything other than 18 pinion when using the 540 motor..
Edit: I see one of the M06 options are 18t pinion, so you can use the Grasshopper 380 motor and pinion as long at the Grasshopper mount will fit.
Time to create page: 0.170 seconds
